Replacing the starter
Old 07-12-2007 | 12:00 PM
coastal_diesel's Avatar
Starter is about to go out so I'm replacing it. I've replaced starters in other vehicles in the past. Anything different that I may have to deal with on the Cummins?
Old 07-12-2007 | 12:03 PM
Joseph H. Smith's Avatar
Why are you replacing it as opposed to repairing it?
Old 07-12-2007 | 12:11 PM
iker42's Avatar
wiki.dieseltruckresource.com/wiki/Starter_Rebuild
Just Fix it....alot cheaper
Old 07-12-2007 | 12:15 PM
I would be inclined to do so but it's my only vehicle, and I don't think the local repair shop could pull it off in a day. I'll call them and see.
Old 07-12-2007 | 12:20 PM
capt.Ron's Avatar
I think I can... I think...
Repair it yourself.....it's pretty easy.
You may just need new contacts in the solenoid.
Old 07-12-2007 | 12:22 PM
clutch1's Avatar
shouldnt take more than an hour to repair and put back on the truck
Old 07-12-2007 | 01:11 PM
Exactly. I replace the contacts in mine a couple of years ago and it is still going strong.
Old 07-12-2007 | 01:18 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I just replaced mine last week. It's pretty easy and took no time at all. The three bolts holding it to the bell housing are a 10mm 21 piont bolt head.
Old 07-12-2007 | 03:52 PM
513yj's Avatar
wow thats a lotta points, the only thing bigger is da tirddy point buck...
Old 07-12-2007 | 03:57 PM
JPR Ram's Avatar
OOPPSSS...I meant 12 point. I type too fast sometimes.
Old 07-12-2007 | 04:16 PM
513yj's Avatar
sorta thunk so...
Old 07-12-2007 | 07:05 PM
ChargerLighting's Avatar
It's easy...I did mine right after I got my '95....contacts were going.
I just replaced the whole thing; figured I need it for work & after 205,000 miles & 12 years, it was about due.
Old 07-12-2007 | 07:41 PM
GAmes's Avatar
I installed Larry Bs kit at about 150k. At about 400k I pulled the started apart and swapped positions of the contacts because I learned from the first rebuild that one side wears more than the other. They showed very little wear compared to the original contacts (that I carry in my toolbox for emergency repair.).
triker888
07-21-2008 08:30 PM
montanacw
10-06-2005 08:29 AM
Paradise Racing
01-18-2005 09:08 AM
MJR
03-16-2003 08:26 PM
Quick Reply: Replacing the starter
