replace torque converter? other mod?
Old 12-17-2005 | 11:48 AM
olsenam's Avatar
I know this question has probably been asked a thousand times but, I am new to the whole auto tranny subject. I have owned my truck for two months. I know a friend of the former owner that told me when I bought it that it had a rebuilt trans and shift kit installed. It shifts very firm through all gears at about 2200 to 2500. If I am accellerating quickly uphill or just punching it, I think that the torque converter is shuddering for just a couple of seconds upon shifting to od, then it goes away. If I am taking it easy on the acceleration it doesnt shudder at all. It just does it going up hill or when I am punching it. What can I do to fix this? I plan on switching torque plates when my guages arrive and I dont want to find out that I could have prevented a blown tranny if I just had repaired or modified a lesser expensive part.
Old 12-17-2005 | 12:26 PM
olsenam's Avatar
At least point me in the direction of a thread that would help. I have searche d and havent found any thing that was quite what I was looking for.
Old 12-17-2005 | 01:48 PM
Big Deezul's Avatar
sent you a pm
have your tranny pressures checked, but it sounds like your converter is giving up
Old 12-17-2005 | 03:47 PM
MnTom's Avatar
You can try calling DTT or you can try calling Dave Goerends and see what they say. DTT is a little closer to you so the choice is your, but I would recommend you call both.
Tom
Old 12-18-2005 | 10:12 AM
95black2615's Avatar
I have a 95 with the same problem. It shudders a bit when you are leaning on it shifting into OD, but shifts fine when you are driving it normally.
Old 12-18-2005 | 11:34 AM
j-fox's Avatar
I think you are feeling the effects of incorrect fluid. Do you know what fluid is in it?
It may be as simple as adding THE CORRECT additive.
Old 12-18-2005 | 07:10 PM
I changed my trans fluid just a few thousand miles ago with ATF +3.
What additive are you referring?
Old 12-19-2005 | 10:06 AM
j-fox's Avatar
Try LUBE GUARD in the black bottle. Try 1/2 bottle first then after a week if it is still there try the rest This is asumming you drive it every day.
Old 12-19-2005 | 01:25 PM
RickCJ's Avatar
If you want the auto to last! Don't be leaning on it when the tc is trying to lock up!!
Old 12-22-2005 | 03:39 PM
mr T's Avatar
first why dont u slide ur plate back into stock position then try some lube guard as suggested...usually the combination is mercon/dexron 3 with a bottle of the lube guard should help with the shuddering
Old 01-05-2006 | 10:31 PM
olsenam's Avatar
Thankks
I have to drop the pan to install the temp sender unit for my tranny temp guage. So, when I do it ill put in the correct fluid and the black additive. When I checked the fluid It seemed to be a bit overfull, does this cause a pressure problem? I sure hope its not the torque converter giving up. I have talked with the previous owner and he assured me that it was replaced when he did the shift kit. I currently am not leaning on it anymore when the converter is trying to lock. (I really want to though) If it is the t.c. I really hope he has the receipt. If not I guess I'll be trolling e-bay for a triple disc.
93dieselZak
06-16-2011 06:10 PM
barryp
11-29-2007 01:51 PM
mainer
07-17-2007 07:13 PM
Flatty
04-28-2005 05:04 AM
Quick Reply: replace torque converter? other mod?
