Rear main leaking & Torque converter question
Well today I checked the oil, 2 and a half quarts low- this is not normal, found no leaks anywhere around the power stearing pump or the front where a kdp could have shot out, but the rear bell houseing has oil dumping out of it... I suppose the rear main has died? Is there any other areas where it could leak?
while i have the trans moved back fixing the rear main or whatever the hell is at fault I suppose I should throw in a new torque converter since the stock one slips after 1/2 throttle in overdrive- I have plans to push this truck up to full fuel plate with boost elbow, my friends says a full tripple disk banks is a must for the 47rh but the $1,000 price is rough- any other good strong converters out there?
Thanks, Joe
Thanks, Joe
the rear valve cover could be leaking too, runs the oil down the back of the block and can appear like a rear main leaking.
mines leaking too
I hope I'm not right behind you with my TC, I think I may have heard it slip but I'm not 100% sure. I just added a #10 plate and it's about in the middle position along with 3k GSK and DDP stage 1 injectors.
havn't really gotten to take the truck thru its paces too much yet as I don't have my guages installed (they all sitting on my toolbox )
I know I have some kind of upgraded TC in there, but danged if I can remember what it is.
mines leaking too
yeah, just checked its dry on the back of the block above the bell houseing. sucks! here is a video of my slipping the torque converter- it creates a vibration and you can see the RPM jump a few hundred when the boost builds at the 1:28 min mark, i also cannot stand how high the engine rev's when its to the floor. way to much gasser DNA in this trans.
NE frmhnd
09-14-2010 06:30 AM
dodgediesel
06-11-2007 09:23 AM
greasy
12-12-2004 10:24 PM
