Rear End Swap
Old 04-10-2008 | 09:46 PM
Big Red 97''s Avatar
Exclamation Need help with REAR ENDS!!!!
I have several questions about rear ends. I have a 97' 2500 4x4 with a 4:10 rear end in it. I would like to go to a higher gear ratio such as 3:73 or 3:55. Which would be a better bet for me to swap to? And is there a certain type of rear end that they put in 4x4's. The 4:10 is killing me on fuel mileage and my RPM. At 70 mph Im at 2500-2750. I need you guys help because I dont know a whole lot about rear ends. If anyboby has a rear with 3:73 or 3:55 gears that they would like to swap or sell please let me know or if you know of somewhere that I could get one reasonably priced. I would like to find one that is relatively local. I live outside of Bryan, Texas. All the hints, tips, and help I can get will be greatly appreciated. Thanks!
Old 04-11-2008 | 10:04 AM
kthiemann's Avatar
The other gear ratio mopar uses is 3:55's which is what my 97 has, running those at 75 mph I'm running almost exactly at 2k rpm. I avg. about 19 or 20 depending on how heavy my right foot is. Not to beat a dead horse but if you decide to change it remember to change both the front and rear gears or you'll tear the transfer case to pieces.
Old 04-11-2008 | 10:54 AM
Thats what I really needed to know was if I needed to swap front and rear. I really don't want to sound stupid but i honestly don't know much about the gearing.Are the front end and rear end geared 4:10? If i need to swap them both what will it cost me? I need the fuel mileage difference and I want more top end than what I get with my 4:10. And the way yours is set up it sounds like you get way better fuel mileage and RPM than me.
Old 04-12-2008 | 01:22 PM
KB440's Avatar
Yes you would have 4.10 gears in both axles now. If you change one you will need to change both front and rear. Cost won't be cheap.
Old 04-12-2008 | 10:21 PM
Ok so does anyone have an estimated guess on what it would cost me to swap both axles for 3:55 and does anyone know where i might could get some at a reasonable price?
Old 04-13-2008 | 10:53 AM
Common's Avatar
See if someone will trade you.
Or check a gear shop.
Old 04-13-2008 | 10:56 AM
Purplezr2's Avatar
I have a front ring and pinion that I will sell its 3.55 set out of a D60. Let me know if you interested, then you just need to find a rear set. let me know if your interested.
Old 04-15-2008 | 02:38 PM
12ValverDave's Avatar
I had my 4.10's swapped out of both front and rear diffs and went to 3.55's. It cost me $1600.00 and have no regrets, still tows like a mule and I have a great cruising rpm on the highway
Dave
Old 04-16-2008 | 11:13 AM
Did it help your fuel mileage any? Did you buy the rings and pinions and have someone do it for you or what?
Old 04-16-2008 | 11:55 AM
Dhorn33's Avatar
I swapped my 4.10's out for 3.55's in November of last year. I bought used gears from a web forum, new Yukon full install kits with all new seals and bearings and found a local guy that helped me with the swap for a very reasonable rate since I wanted to help and learn how to do it. In the end - I spent around $700 then sold my 4.10's on Craigslist for $200 so my out of pocket cost was only around $500. This was super cheap!
When I called around to local shops to get prices on the install I was given prices in the $1500-$1700 range by the time I bought the install kits and used gears. Labor alone was about $1000. If you can fnd someone to give you a deal if you help out then that is the way to go imho.
I cannot really comment on any fuel savings because the day I did the swap it snowed and got cold and I didn't drive the truck much over the winter due to high fuel prices. I was hoping to gain 2-3 mpg and better drivability on the highway.
Old 04-16-2008 | 04:58 PM
I saw a 1-2 mpg increase on the highway and a slight decrease around town, and $1600.00 was new ring and pinions, master install kit for front and rear. All I had to do was drop the truck off, lol
Dave
Old 04-16-2008 | 04:59 PM
And I too sold old ring and pinions on the internet for $175.00
2500CTD
10-19-2010 07:10 PM
doorguy
06-08-2007 06:19 AM
TEDHRS
09-08-2004 03:04 AM
BIGHEAD
06-24-2004 07:08 PM
CAPTDASH
01-15-2004 05:06 PM
Quick Reply: Rear End Swap
