Rear end hoping....
Old 07-04-2007, 11:25 AM
xzaq103's Avatar
Rear end hoping....
My rear end is hoping like someone is jumping in the bed as im driving down the road. It started after going to 285's and its not the tires i have had them checked and re balanced. It only seems happens when im cruising or slowing down with the engine at idle and if i get on it a little it seems to go away. Any ideas?
Chris
Old 07-04-2007, 01:44 PM
DRM14's Avatar
Axle wrap, maybe? Maybe you need a set of traction bars.
Old 07-04-2007, 04:46 PM
kawi600's Avatar
When youre coasting and not when youre on the throttle? Ring and pinion problems? Maybe have a look at the driveshaft and transfer output. Something fishy there.
Old 07-05-2007, 10:27 AM
Stamey's Avatar
Is there a particular speed where this starts to happen? I ask because I encountered a driveshaft vibration in my 99, but it only happened above 75 mph. It was the u-joints, even though not a single cup was dry when I pulled them apart. New u-joints and all's smooth through 100+ mph.
Now this didn't feel like the bed was jumping, but is was a significant vibration once I hit 75+ mph.
Chris
jmccart
15
09-18-2007 08:02 PM
wild4stangs
08-13-2007 10:48 AM
red12valve
07-25-2006 07:34 PM
FIRECAT7000
03-07-2006 10:59 AM
2500CTD
05-14-2005 04:06 AM
Quick Reply: Rear end hoping....
