Rear axle nut "keeper" option
Hi, i just replaced the rear axle seals and i need new "keepers" -small slotted steel pin that hold the axle nut in place and from backing off. The *********** wants $13. ea.for em, and can't get em in til next week. Is there a Napa/parts store number for em??? I need to get back to work ASAP!
Thanks
Cheers!
Thanks
Cheers!
axle keeper
I read some where a fellow posted that you can replace the nylock nut and keeper with the double nut and retainer that was used many years ago. If the nut backs off it can cause you a lot of problems. Jim
Cummins Guru
If the nut goes on easy by hand then replace them too. The left side nut will unscrew and you will loose the wheel, so be safe and replace it and bite the bullet.
Cheers!
91.5CTDBanks
07-10-2009 11:34 PM
barney1
11-07-2008 04:37 PM
