pump timing question
Old 03-29-2006 | 07:48 AM
JKM's Avatar
JKM
What did you guys use for a gear puller? (pics)
You can make your own gauge holder out of an old drain plug (or a 22mm bolt, 1.5 thread)
Old 03-29-2006 | 08:56 AM
halerazor's Avatar
i used the one that comes with the snap on kit
Old 03-29-2006 | 09:16 AM
robert chilton's Avatar
I used the snapon puller also. Worked great. In reality any flat puller that is slotted for 2 bolts, like a balancer puller but smaller, would work. I was going to make all the tools to do my timing but couldnt find a drain plug locally so I just ordered the DV socket, puller, and gauge adapter from snap on. It was cheaper than buying the DV socket locally also. The diesel shop wanted $100
Old 03-29-2006 | 11:04 AM
Dusty Ratcliff's Avatar
I got a steering wheel puller from Autozone for like $15, then you just need the right length/thread pitch bolts, I found some grade 8 bolts at a local hardware store for a few bucks, Dusty
Old 03-30-2006 | 06:57 AM
marine4life's Avatar
thanks guys, after reading the instructions many times i kicked myself. hey atleast i can tear an m-16 down an put it back together in 40 seconds, that's good for something right . i'm gonna give the timing a shot on saturday, hope i have enough time, i promised my buddy i'd put his cold air intake on his ricer, please forgive me
Old 08-30-2006 | 07:30 PM
wcbcruzer's Avatar
Hey do you remember what size/length bolts you used?
Old 10-15-2006 | 10:06 PM
2500's Avatar
was the 1 3/16 socket used a 6pt or 12pt ?
this would save purchasing the special 32pt special socket necessary according to instructions
snapon is out of the DV socket too..
Originally Posted by robert chilton
It is a tapered press fit. You should really buy a new lock waser and nut for it also. The nut is metric and I used an 1 3/16" socket on it. Nut and washer is cheap from cummins.
Old 10-16-2006 | 01:18 AM
97ramctd's Avatar
steering wheel puller and the short intake horn bolts work to remove the gear.
Honkylips
10-15-2007 07:07 AM
GR40RCapri
06-25-2006 12:53 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
redhornet
05-28-2004 06:06 PM
Quick Reply: pump timing question
