pump timing problem, my BAD!!
i pulled a p pump out of a 95, i put the motor on TDC but when i put the timing pin in I didnt get it in far enough like i thought. and the pump timing pin is not in the pump it was already missing. any way we were putting the tranny in at the same time the pump was out and the motor has moved. im just not sure if the timing pin wasnt exactly lined up when i took the pump off, and if i put it back on tdc and do it, if the pump timming will be off some. sorry if this sounds confusing, thanks- Kyle
