Pulling injectors
Old 03-10-2004 | 10:09 PM
heap's Avatar
Pulling injectors
Does anyone know an easy way to pull a stuck injector.
Old 03-10-2004 | 10:44 PM
jrs_dodge_diesel's Avatar
Pull harder? Sorry, couldn't help myself. I would try using a pry bar of some sort.
Old 03-10-2004 | 11:04 PM
HD MECH's Avatar
New to the forum
You could try using a slide hammer using a old injector nut welded to a bolt that will attach to the slide hammer. This has worked for me in the past Red
Old 03-11-2004 | 01:26 AM
Got Smoke?'s Avatar
Go to the hardware store and get a metric nut 14MM x 1.5 pitch (don't be surprised if its cost's almost $2!)
Screw that nut down on top of the injector and use a pry bar to pop it loose!
We just put my old Marine 300's in my buddies 95 last night, and his stock injectors with 200,000-PLUS miles came out a lot easier than my 300's did and they had only been in there a year when we put my PDR 370's in!
Old 03-11-2004 | 05:52 AM
berner's Avatar
I used a 14mm nut on an old 5/8" X 5" long bolt with a heavy 3/4" drive socket to make a little slide hammer. Slip the socket on the bolt and screw the nut on. It'll only go on about a turn or so. Screw the works onto the injector and slide the socket up quick a few times. It might help to take a brass drift and hammer and tap on the side of the injector first to loosen it up a bit.
Old 03-11-2004 | 09:13 AM
gunracer1's Avatar
i chevy 1/2 ton lugnut fits the top threads, if you stack up some of the big nuts from the other injectors up on the stuck ones, you can pop it right out.
Old 03-11-2004 | 09:34 AM
infidel's Avatar
Assuming you have stock 12 valve injectors. Grind a 1/2" pvc or steel plumbing coupling down so it's 1-3/8" long, slip this over the injector (lines removed of course) then screw a lug nut from your truck down where the inlet line attached. The coupling will push against the head while the nut pulls up on the injector, it won't feel like you are getting any resistance at all, the injector will pop right off. This is especially useful for the rear ones where there is no clearance, but works better than any other method I've tried including slide hammers and pry bars.
Old 03-11-2004 | 03:26 PM
superstreet's Avatar
I used the same method as infidel, and it worked great.
Old 03-15-2004 | 10:32 PM
radixr's Avatar
3/4" E.M.T. works well also. Best to cut it with a tubing cutter so the ends are parallel.
morkable
ABDTR #5
02-22-2009 06:51 PM
KRB
05-20-2007 06:20 PM
mullercarl
Competition / Pulls / OffRoad
45
03-19-2007 10:10 AM
pullin hard
04-21-2006 09:41 PM
BIGOKIE
07-21-2004 05:53 PM
Quick Reply: Pulling injectors
