Popping sound on left front side of the truck
When going up slightly elevated ground/terrain, the left front side tends to make a "pop" ing sound..
The right front side of my truck has had the ball joints replaced (I think, just because that side has grease zerks.. Or maybe the factory ball joints were greasable and the other side was replaced, I'm not sure..
Do you think ball joints are the problem or do other things in the front end make this sort of noise as well?
Wheel bearings, tie rod ends, and sway bar are all good..
I do not have death wobble anymore, since I installed a set of BALANCED tires, but the caster adjustments are still not quite as high as I want them (based on Cowhand's specs)
If they do indeed need to be replaced, should I get the adjustable ones right off the bat?
Let me know what you think..
Thanks in advance.
Thanks in advance.
I would start with the ball joints. To check them, jack that side up just enough to get a long bar or pipe under it. Then lift up while someone else is looking at the ball joints. If you see play, it's time to have them changed. I would also take a good look at the trackbar. They are also a ball and socket and will pop when bad.
My guess would be axial u-joints , get wheel off ground and try to move u-joint by hand , after replacing many , I've found that every so often you'll get a bad one bound up and not be able to feal any movement.
My 96 has a ticking noise, which I thought might be the LS unit, mostly noticable when turning sharply right. Friday I had someone else listen, from outside the truck, as I turned, and he said it was coming from the front, maybe a u-joint. I put it in 4WD and turned as sharply as I could. The ticking went away. I will be looking harder at the u-joints for final diagnosis.
Chris
Chris
Idaho Guy
16
02-12-2020 11:15 AM
Delmar
14
11-07-2011 07:14 PM
buldaawg
13
04-23-2008 09:17 PM
VikingDiesel
02-20-2008 01:24 AM
