poor idle
poor idle
ok hi everyone and thanks for taking the time to help,here is my problem. first my truck takes 5-8 seconds to start then it will run at about 4-500 rpm for a few min then slowly move back up to normal. second after running down the road for a while when i come to a stop light it boggs down again to 4-500 sometimes. if i run the a/c it will bog down every time i idle. i,v checked my fuel pressure and that is good also did a fuel leak down test and that was fine. i just rebuilt my fuel preheater and screen and still the problem persists. any help would be much appreciated thanks.
hi
is your idle speed hi enough ?
850 rpm i think mine says , on the engine speck plate i believe ?
dont want less than 750 in gear with ac ,it will help intrafic engine cooling and ac operation !
AkitaSumo
50
05-01-2009 07:38 AM
