please help fix vibration
my truck has been vibrating for a while now, and its steadily getting worse. the vibration occurs mainly while deaccelerating from speeds of 30 mph or above. it does this whether i am using the brakes or just coasting. i have put all new parts in the front end, and had it aligned, and the tires have been balanced. i can't see any missing weights from the driveshaft, and the u-joints don't seem to be bad. i think it is coming from the rear end or driveshaft maybe. funny thing is that when i have some weight on the back, or am hitched to the boat, it almost dissappears. please help, it is driving me nutz and i am starting to not want to drive it.
yeah, its the rearmost u-joint thats bad, which probably led to the driveshaft support bearing problem. and it does pretty much go away while i'm on the throttle. i'm just going to replace all three u-joints and the support bearing on friday with good parts that actually have grease fittings.
hoot
122
08-02-2004 08:38 AM
routerguy99
09-01-2003 06:56 PM
