Pensacola diesel injection pump first 1000 miles.
OK as some of you may know my good old p7100 bit the dust about a month ago. SO I purchased pensacola diesels "HOT" pump and I think ill do a little right up about the first thousand miles and what I think so far. Ok so hear we go I purchased the pump and there stage 2 injectors that give 70-90 hp over stock I had them installed at the same time as the pump. The pump is set up to flow 350 cc at 1000 strokes. and timing is at 17* I will be lowering the timing in the next few weeks. To be honest at first I was a little upset it felt like my other pump with the #10 actually maybe a little slower. Turns out I had a fuel leak. One of the fittings was not tight and the star wheel needed some tweaking. After that it felt like it had roughly the same power as my old pump with the #10. Keep in mind this is with the stage 2 sticks. So I ran like that for about a week. This weekend I was bored and decided to pull the afc off and put in some tst springs. when I got the afc off I noticed the plate was in the stock position. so I pulled the plate to take a look at it. Its pensacola diesels own custom plate. Its a very interesting design if any one wants pics shoot me a message. Anyway I put the #10 on and tweaked the afc both at full forward last night I went for a test spin. WOW She can easily break loose in 2nd and in chirp in 3rd. it feels like a 35% improvement in power over what it was when I first got the new pump installed. The next things on my list are a 3k gsk and turbo/4 inch but that will be a few months for now im loving this power. I estimate im in the 400 hp region I hope to dyno it June 9th to find out for sure ill keep you guys posted. So far im really liking this pump. the only things I bummed about is that there were break off screws on the afc and that pensacola said she would run up to 3100-3300 rpm. she doesn't only to the upper 2k range.
Chris
Chris
Nope its a remand. And well I tried to install a gsk kit and it did not go well I guess the nut that holds everything on came off bent the stud and broke a lot of stuff inside the pump.
Chris
Chris
Before I put the #10 on I didn't like them that much but after installing the 10 I can tell a deference. Also the idle seems a little smoother but I cant say for sure if the power or the idle is from the injectors or the pump since I put them both on at the same time.
Chris
Chris
tommurray
02-23-2014 10:38 AM
xzaq103
06-11-2007 09:49 PM
ckennedy
10-07-2004 06:57 PM
