P7100
P7100
Does anyone have a list of P7100 part numbers and which CPL they were used in? I have a 1998 12-V that has a Cummins 230hp upgrade pump on it. I need to identify the pump in order to time it.
thanks
thanks
Tate, I plan to buy a mirror and try to read the pump number, it is well hidden. If not I will have the shop read it while they do the KDP fix.
Skip, do you happen to know what plunger lift gives 12.5 degrees on your CPL1553 engine? The shop checked mine and said it was at 16 degrees, but they were using CPL 2175 data (original data plate). It seems that Cummins NW did not change the data plate when they put the 230hp upgrade in.
thanks
thanks
Unbolt the linkage to the pump. Its 3 bolts with 10mm heads. Post that number here. If it's an aftermarket 'upgrade' to 230hp, its probably a different plate and gov springs in a 160/175 pump. If its a true 230hp pump, then its a different matter.
OK, here is what the shop found when they removed the linkage plate.
Serial # 3272201 Model # M03209803B-L. They have no idea what pump it is. They suggested I call Cummins and ask them.......can anyone shed some light on this?
dyno
take it to a dyno shop and pay them the 150 to run it so u can tune it in
start at 12.5 then 14.5 then 16 degrees and see what ya get?? most cummins shops have them in there jus look up dyno shops and call around to see if they do diesel pickups
