Overflow valve and lift pump
Old 11-14-2007 | 12:04 PM
coastal_diesel's Avatar
A while back I bought a spare overflow valve and lift pump, when my fuel system was making a ticking noise. It turned out that it was just a dirty fuel filter resulting from my hunt for cheaper fuel at a station I had not used before (they've since gone out of business).
Anyhow, I was wondering if you need a copper O-ring when replacing the overflow valve (although the Cummins parts man did not offer to sell one). When it comes to changing it is it just a matter of unscrewing the old one and screwing the new one in?
The lift pump came with only one gasket-- do I need a second one for the pump mounting block as well?
Old 11-14-2007 | 01:38 PM
TIMMY22's Avatar
re-use the old crush washer on the overflow valve.
One gasket for the lift pump. Use studs instead of the bolts and it will save a lot of swearing. Take out the starter and go at it from underneath.
Some folks take the tire and the plastic molded mud gard off to reach it. Too much extra work if you ask me.
Old 11-14-2007 | 03:39 PM
97' CTD's Avatar
Yes, use two gaskets and gasket sealer. IMO
Brandon
Old 11-16-2007 | 07:48 AM
Could you tell me the threads, recommended length, and stud sizes for the lift pump so I could have them ready ahead of time?
Old 11-16-2007 | 02:02 PM
TIMMY22's Avatar
2 @ 8mm x 25mm long 1.25 pitch plus nuts and washers.
RedChevitz
09-30-2008 11:07 AM
mainer
01-10-2007 07:16 PM
flightmedic992
12-25-2006 09:31 AM
rollsroyce1999
07-07-2006 02:51 PM
qwest
06-16-2006 06:52 AM
Quick Reply: Overflow valve and lift pump
