Oil Quick Drain Plug
Old 02-06-2008 | 10:20 PM
Fueling around's Avatar
Originally Posted by thewished
Sorry but I do know anyone who has a cumminGs under the hood. But I'm sure others will help with your cummins
We use Cummins G series. They burn natural gas and have spark plugs.
Old 02-08-2008 | 12:20 PM
Hercules's Avatar
Is anyone using the version of this plug with the little lever for releasing the oil? I think they called it "finger touch" on geno's website.
Old 02-08-2008 | 02:52 PM
WVAussie's Avatar
I have that one. I like it, its out of the way up behind the axle. I put a small hose clamp around the body of the valve and it stops any accidental drain.
Old 02-08-2008 | 05:00 PM
Hercules's Avatar
WVAussie, I noticed you said you put a hose clamp on the valve. Doesn't the lever have a little indent that it rests in until you open it and is the lever just simply too easily dislodged to an open position that clamping the outlet off was necessary?
Old 02-09-2008 | 07:14 AM
WVAussie's Avatar
yes it does have a detent and I think that would work just fine. The reason I put the hose clamp on is I've got 4 boys and experience with them.
jj3500
01-16-2008 02:42 AM
jj3500
06-10-2007 12:02 PM
blafleur
06-16-2003 05:45 PM
apc
02-28-2003 08:47 AM
m batterson
02-19-2003 10:03 PM
Quick Reply: Oil Quick Drain Plug
