Oil Pressure Problem
Hey guys, I am new on here so I hope you can help. I have an oil pressure problem at idle. It is up where it should be out on the road but when I let off it to stop it goes down to nothing and the light come on. Any ideas?
Check your oil pressure with a mechanical gauge. Most likely its the oil pressure sensor.
I had the exact same symptoms as you. Bought a mechanical gauge, removed the old sensor and hooked the line for the gauge and havent looked back since. I bought a 50 ohm resistor from radio shack to keep my check engine light off.
Now I know exactly what my oil pressure is...no worries
Are your batteries old? I was having some weird electrical problems--I was running 10-year old Optima's--and when I checked the voltage one was only putting out 8 volts. After I changed them out the electrical problems went away.
Oil Pressue Problem
Thanks guys, I found the problem to be the oil pressure sensor. I replaced it at a cost of about $18 and the cost of a $10 socket to make the change, so I got off easy this time!
No biggie, now that you know you have good pressure, if it messes up, just get one from Cummins.
most likley the electric sendor, i run my idle at 400rpm and it holds great pressure. the manual says to use 10w30- the pervous owner ran $0.49 cent a quart havoline 10w30 for 200k without any issues.
I noticed that as well, the rest of the information looks accurate but the oil seal isn't for a cummins. Biggest give away is where it says "for gasoline engines".
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
callum
11-21-2004 07:04 PM
