Oil Plug
Oil Plug
When I purchased my 94 last month my Oil plug was leaking. I took it off and put some black RTV and fixed the problem. The dealer I purchased the truck from ordered me new plug and I recieved it last week. The oil plug in my truck now has a nut to remove the plug. The new oil plug has a allen screw. How do I figure out which plug is correct???? I am due of an oil change and want to make sure I have the correct plug before I change it. Does some have a part number for the oil plug on a 94 CTD 4 x 4? Thanks.....
Dave
Dave
Well I have a 96 CTD but when I broke my oil plug I couldn’t but the new one because they made a smaller plug which also meant that I had to pull the engine to remove the oil pan so that I could put the new oil pan in and put my little oil plug on there so it would not leak. That really sucked.
The original required a 3/8's inch ratchet to remove. Just the square part of the ratchet drive. I don't think it is the plug that is causing the leak. It is the distortion of the oil pan from improper torqueing and the oil drin plug gasket. Here is a great source for drain plugs for anything:http://www.cgenterprises.com/
After use, it seems the stock gasket does not seal well. This is what the stock plug looks like:http://www.businessvision.net/edge/M...oduct&SKU=1031
Get this gasket and you will be set:
http://www.businessvision.net/edge/M...duct&SKU=2008W
Just the new gasket will stop your leak. Take a look around that website. They have different types of plugs for your truck, including magnetic, and different types of gaskets/material as well. The nylon gasket was the fix for me. I like the magnetic plug as well.
These plugs have been know to develop a hairline crack.....causing leaks
Try a HD type plug:
http://www.genosgarage.com/CoastalDa...ID=408&CATID=1
Or a quick drain type plug:
http://www.genosgarage.com/CoastalDa...ID=210&CATID=1
http://www.genosgarage.com/CoastalDa...D=1013&CATID=1
Try a HD type plug:
Although I don't believe in the valve type oil plugs they are an excellent alternative when the the pan is distorted. Just clean the pan well, goop it up with silicone and never remove the plug again.
After use, it seems the stock gasket does not seal well. This is what the stock plug looks like:http://www.businessvision.net/edge/...roduct&SKU=1031
Dave
jlipskoc
02-21-2007 12:13 PM
