oil pan removal
I have , I use a cherry picker, remove the motor mount bolts and jack the engine up highest you can ,drop the pan down down and reach in over the pan and remove the oil pick up tube with a 10 mm wrench and drop it into the pan and then the pan will come out . install the same way with the pick up tube resting in the pan , set it up in position and then install the tube and pan last.
bostongsx
09-25-2006 11:25 PM
