Oil out of Blow by tube
Yes i have a question what does it mean if oil is flinging out of the blow by tube.? the way i see it is .. the piston rings are gone in the engine and it was caused by over fueling..? if that is the case how hard is it to change the rings??
It could be a leaking vacuum pump from what I have read. Your best bet would be to use the SEARCH function near the top of the page. There should be many threads on this already with a lot of information.
Diesel-Dan
11-06-2016 12:31 AM
