oil leak behind filter, need gasket?
Old 03-05-2003 | 11:11 PM
bigbaddiesel's Avatar
So i had an oil leak, finally got fed up enough to degrease engine, and i think i found where its leakin from.<br>There is a plate right behind the oil filter. It is a little longer then then the filter and about as wide. The part that you screw the oil filter onto is mount on this plate. I dont know what the plate is or what is behind it. I would like to replace the gasket. So, is there anything important back there that will come flying out? Will the ******* know what part # i will need? Thanks in advance for any help.
Old 03-05-2003 | 11:19 PM
SmokinDodge12V's Avatar
Re:oil leak behind filter, need gasket?
That is your oil cooler its not a hard job to do but it has two gaskets it is two pieces with a gasket between each piece. I think one gasket runs somewhere around 15$ and the other 24$ at your local cummins parts dealer and the only thing that should come out when you take it off is a lot off water or coolant.
Old 03-06-2003 | 01:26 PM
thanks for responding. good to know i can take that off without losing something that is hard to replace.
robby t
12-16-2013 09:22 PM
dieselfuelonly
01-24-2012 10:16 AM
seahawkdodge
09-18-2011 11:14 PM
djbikeman
17
01-31-2006 09:31 PM
4x4
12-31-2003 10:37 AM
Quick Reply: oil leak behind filter, need gasket?
