oil hose on bottom of motor??
It's normal to have a little wet spot on the differential below the vent tube. But if there's enough oil that it's blowing back and soaking the transmission, that's not normal. I've seen a couple trucks where there's enough oil coming out of the vent tube that it's dripping off the back bumper. That's too much.
whats the fix for this?
Paint the pavement not the bottom of the truck.
if you have excessive blowby one culprit could be that you have worn piston rings, which when this happens the piston does not make as tight of a seal on the cylinder walls and allows the compression to leak by and blow the oil out of the crankcase, and therefore out the breather, however like said if you are not blowing oil all over i wouldnt suspect the rings are bad, but it might not hurt to have the compression tested.
It's nice and easy if this is in fact the culprit, if not, engine wear is the likely cause, and Infidel's advice is a great solution.
Been dealing with a little puddle and no cruise for several months... just got my head out of my A$$ and checked the vac lines. Found a leak right near the pump! Fixed it, now cruise works and no oil leak!
RHC
03-04-2011 08:22 PM
1985cucv
07-18-2008 07:29 AM
