Oil drain plug
Oil drain plug
Just a heads up while changing your oil, CHECK YOUR DRAIN PLUG! Today while changing my oil I decided to replace the plug gasket so after removing the old gasket and washing the plug in the parts washer I noticed the collar was cracked all the way around I guess I must have over tightened it I will see if I can post a picture
Seems like the people who use a torque wrench end up breaking them. I just snug the plug up with a 8'' long ratchet. It's never fallen out or leaked, in fact usually takes a two foot cheater bar to remove it. Still on the same plugs and washers after at least 50 oil changes on both rigs.
Get one of these babies and you wont have any more problems:
http://216.167.41.9/CoastalData/show...D=1008&CATID=1
