nv4500 oil change
Old 12-14-2009 | 04:44 PM
sabercat's Avatar
is that what the dodge nv4500's take 5 qts? I was at carquest today, and asked about oil for the trans, he said something like 9 qt's and a syn oil, he had 75-85, GL5, I said that does'nt sound right.
Old 12-14-2009 | 05:57 PM
traverler48's Avatar
It is my undestanding on the nv4500 2x4 it takes 4 qts gl4 I don't know about the 4x4 the cheapist I have found is $23 qt close to where I live from dealer. Quad 4x4 had it for 38.97 for 2qt but by the time I paid shipping it was more.
Old 12-14-2009 | 07:46 PM
torqueshop's Avatar
I Ran Amsoil It Was Great!
I had some one almost jack my trans by putting in some regular man trans oil..... Syncros started getting sticky hard to shift especially cold... Then I flushed it and put amsoil and flushed again and amsoil and it cleared up and shifting remained perfect after that....
I would do Amsoil again.
J
Old 12-15-2009 | 07:15 PM
95black2615's Avatar
The phone number posted in the ebay ad for "Mary" is a direct line to Blumenthal manufacturing. It might be legit. I'd call em up and ask if they have ebay ads for NV4500 oil.
If it is I need 10 quarts
Old 12-15-2009 | 07:54 PM
sabercat's Avatar
Where can a person, find the how to change the fluid in a nv4500. I search alittle on here but did'nt really find a post on how to do it, from start to finish.
I checked on 411 search engine, and the # did come up as Blumenthal manufacturing. Thanks
Old 12-16-2009 | 10:07 AM
infidel's Avatar
Instructions are a snap.
Warm tranny by driving, remove a lower PTO cover bolt, let it drain.
Replace bolt, fill tranny to the bottom of the fill plug hole.
A cheap hand pump makes it easier.
Old 12-16-2009 | 03:56 PM
sabercat's Avatar
Thanks, I bought some of the ebay oil. I'll probably have some left over, right? thanks again
Old 12-17-2009 | 06:13 PM
Well I called Mary at Blumenthal today she said the nv4500 oil was Castrol Syntorq. I orded the 5qts for 53.90 with free shipping. Never dealt with this ebay stuff but from what I could find out they seem like a good Co.
Now to figure out what to do about the rear end the last time I changed it I used Valvoline 80W90 none syn. and additive from dealer got 45k on that change almost time to do it again. I am afraid if I go to a Syn. I will have leakey seals.
Old 12-17-2009 | 06:26 PM
infidel's Avatar
I see the Blumenthal instructions on ebay say to add the oil though the top by removing the shifter.
Works good if you don't have a hand pump but don't overfill above the bottom of the fill plug.
More is not better and will make the tranny run hot.
Old 12-17-2009 | 08:09 PM
sabercat's Avatar
I'll just fill thru the side fill plug, maybe I will have a extra qt left over.
Old 12-21-2009 | 02:06 PM
sabercat's Avatar
Got the oil today, I just filled it to when it came out the fill hole. Big differance, works great.
Old 12-21-2009 | 02:14 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Did you see big difference in the operation of the tranny?
Old 12-21-2009 | 03:34 PM
sabercat's Avatar
shifts better, and does'nt make as much noise. The stuff that came out, smelled really stong, of gear lube. I think it was straight regular gearlube. I have about a qt left over of the new
Old 12-21-2009 | 03:54 PM
Thanks...I should change the oil in my trans...Only fuild change I haven't done yet...Great to know I need 5 quarts..
Old 12-21-2009 | 05:42 PM
sabercat's Avatar
I used a little hand pump, I got at walmart, to put it in.
Quick Reply: nv4500 oil change
