nv-4500 from a V-10 fit a CTD?
Old 03-19-2009 | 07:09 AM
I have a totalled '96 stick shift V-10 that has a great drivetrain. I was looking for a CTD engine to convert my '85 Dodge crew cab W-350 from a gas 360 4 speed that is in it now. We all know finding a stick shift CTD truck is harder. If I was to find a CTD out of a auto truck would my NV-4500 bolt up. I know they offered that tranny with the CTD in 94-02 as well as the V-10.
Old 03-19-2009 | 09:44 PM
ttcfan4476's Avatar
from what i was told the v-10 and the ctd share alot of parts including radiator and motor mounts and trans bell housings
Old 03-20-2009 | 06:06 AM
The radiator was crushed in car/truck accident but I was hoping to use the trannny. It would be cool to have motor mounts to use too, though they will probally need a little modding to fit a '85. If the bell housing bolts are the same does anyone know if the input shaft is the same?
Old 03-20-2009 | 08:46 AM
BigErksG2's Avatar
should be the same but shift points are a little higher on the gasser. easily changed by swapping a pressure spring inside the tranny.
Old 03-20-2009 | 11:14 AM
rattlerbob5.9's Avatar
Never seen any of those in an NV-4500 5 SPEED !!!!!!!!!
He was asking about a manual tranny NOT AN AUTO.
And actually it is the governor weight assy that needs to be changed when using a v-10 gasser auto behind a cummins.
Otherwise it will not shift correctly.
Old 03-20-2009 | 01:25 PM
BigErksG2's Avatar
hahaha youre right.... it was early.
Old 03-20-2009 | 05:39 PM
So it will bolt up? Can I use my V-10 flywheel or are they balanced differently? Thanks.
Old 03-20-2009 | 10:52 PM
Yes the tranny will bolt up. No on the flywheel.
Thiss
10-20-2010 12:07 AM
JPR Ram
03-27-2007 03:58 PM
2500
02-24-2007 11:44 AM
v8440
04-10-2006 04:05 PM
Magnaflow
09-14-2004 04:38 AM
Quick Reply: nv-4500 from a V-10 fit a CTD?
