NV 241 Tranfer Case change LT. to RT drop
Old 10-05-2009 | 08:56 AM
JD730's Avatar
What I meant was get a 80 to early 90's married NP205 out of a dodge. It will bolt right up to the 47RH. They shouldn't be too difficult to find.
Old 10-07-2009 | 09:23 AM
GAK30's Avatar
The 6-bolt pattern on front of the Chevy case is clocked differently than the Dodge. Chevy has single bolt at top and Dodge has 2 bolts at the top. Dodge did use a rh drop 241 in the 1/2 tons in the early 90's though.
Old 01-28-2010 | 01:48 PM
Carl's Avatar
Finally got the trasfercase I wanted, 241D out of a 88 ramcharger had RH drop and mate up to the 47RH trasmission. shorten front drive shaft and new on rear drive shaft. eliminated all vibration of the divorced transfer case. Done!!
Old 01-28-2010 | 06:08 PM
user name's Avatar
The 205 came in the diesels up through 93, it will bolt right up to the 47RH if you can find one.
ram 2500
12-08-2008 08:07 AM
ram 2500
12-07-2008 12:45 PM
garthed
02-03-2005 10:38 PM
sdgunslinger
12-23-2002 12:27 AM
Quick Reply: NV 241 Tranfer Case change LT. to RT drop
