NV 241 Tranfer Case change LT. to RT drop
Old 09-29-2009 | 03:00 PM
Carl's Avatar
I have a 47Rh Transmission 2x4 behind 5.9 Cummins and want to convert it to a 4x4 tail housing, will a NV 241DLD or NV 241DHD be clocked to a right hand drop?? I'm changing from Divorced 205 to 241 but need to have a right hand drop with out changing my dana 60 to left drop. Will any NV 241 work??
Thanks
Old 09-29-2009 | 06:33 PM
1-5-3-6-2-4's Avatar
no you can't run them upside down. you'll disrupt the oiling and failure isn't far way.
whats wrong with the divorced 205 behind the 2wd 47rh?
you can put the dodge 241 input into a Chevy 241. and have RH drop. but you can't flip a dodge 241 upside down.
Old 09-30-2009 | 11:25 AM
Carl's Avatar
the drive shaft between the 2x4 trans and 205 is so short I can't get the vibration out. any Ideas? could use one! How hard is it to 241 input in a Chevy?
Old 09-30-2009 | 11:34 AM
how short is short? mine is/was 23" from my 47rh to ford divorced 205. I didn't have a vibration.
but how are your joint angles? hopefully the shaft is phased correctly. who built and balanced it?
Old 09-30-2009 | 04:30 PM
Tate's Avatar
Chevy had RH drop 241's? I thought they were either 205's or 208's.
Old 09-30-2009 | 06:07 PM
I was going to swap 241 inputs for the dually at one point.....mmmm you might be right. maybe I was planning a chevy input into a dodge case.
Old 10-01-2009 | 10:26 AM
Carl's Avatar
The drive shaft lenght from the front of slip yok to end of ujoint is about 12" maybe 15" not very long. I had to push the gas tank and 205 back 6" in order to get that to fit. the 74 short box with the 47rh don't give me much room. can you run a Lt. drop 241 with two cv joints to run a right drop dana 60?? or two much angle.
Old 10-01-2009 | 10:31 AM
Carl's Avatar
anouther question is any dodge NV 241 work behind a 47rh 4x4?? gas or diesel, I don't go mudding that much, but will it hold up under normal driving??
Old 10-03-2009 | 03:36 PM
riddle789's Avatar
I don't see this working out very well.
If you address the oil pump pickup location, it is possible to run one upside down. We installed a NV273 out of a super duty into an '89 W350 with a getrag. Lacking the equipment to weld aluminum, we had a guy weld a piece of aluminum to the raised surface where the number tag was located, and then drilled and tapped it for a fitting, and used this port to run an oil line up to the top, where the oil pump is now located. We then drilled thru the case and attached our oil line to the factory pump in the transfer case. All in all it really wasn't that bad, considering we had to completely disassemble the t-case to change the input gear anyhow (it was out of an automatic super duty).
Granted this was all done on our puller, but it does see some highway use as well and has worked well so far...
Old 10-03-2009 | 11:03 PM
Carl's Avatar
Thanks Riddle 789, this gives me at least a direction to head. still hope this or any other sugestion will work.
Old 10-04-2009 | 06:06 AM
JD730's Avatar
Thanks
Whats wrong with using a dodge 205 right hand drop? It will bolt right up to 47RH tail housing.
Old 10-04-2009 | 06:53 PM
riddle789's Avatar
im assuming he wants the lower low range that the planetary style transfer case provides...if not then a 205 out of a first gen would be the easiest way to go...
Old 10-05-2009 | 02:36 AM
Tate's Avatar
Maybe a 203/205 doubler if he wants the low range. Talk about beef, and you still have 2:1 low range if wanted.
Old 10-05-2009 | 08:39 AM
Carl's Avatar
JD 730, I really don't need the low range I like the 205, but didn't know that you can hook it up to a 47rth 4x4 tail housing! is there an addapeter out there??
Old 10-05-2009 | 08:45 AM
Carl's Avatar
JD 730,
You say that a 205 divorce can be mated to 47rh? who or how can this be done? I like my 205 its bullet proof.
I really want to go with a chain drive, plus I just put a xxxx load of money in the drive train on the 74 dana 60 in front with power traxx and dana 70 power lock in back. Drive shafts are nothing of cost compaired to all the front end change out.
Quick Reply: NV 241 Tranfer Case change LT. to RT drop
