not much smoke?!
Old 07-26-2007 | 12:50 PM
513yj's Avatar
really can't say since ya got nuthin in your sig. i'm thinking you might need so different dv's if you have injectors. if you have stock injectors and fooled around a lot they probably don't flow enough fuel. not lotsa fuel not lotsa smoke. my wheel is cranked, afc diaphragm washers swithced, ground 10 plate full forward, afc full forward and mine smokes similar to yours. smoke screw is stock location. i don't want it smoking a lot anyhow since smoke = cash money up in smoke.....
Old 07-26-2007 | 02:07 PM
jstrdiesel's Avatar
custom marine injectors,100 plate all the way forward, afc spring kit, 3gsk washer, k&n bhaf, star wheel maxed, boost elbow.
Old 07-26-2007 | 03:06 PM
513yj's Avatar
yeah, probably some dv's then or timing bump. with what you have is close to what i have and those are my next two things along with injectors and exhaust, exept i don't want to much smokeshow. it smokes at takeoff and when i'm cruising and give it some rug then it has a breif shot of smoke. the only drawback is i got the auto and with 180 on the ticker i'm gonna wait to upgrade till it shats out. hopefully by then the motor bombs will be done and i'll have the combo i want.
PK
10-19-2003 10:28 AM
pjram2002
07-08-2003 03:55 PM
jbs007
07-08-2003 01:29 AM
97CTD
03-17-2003 08:14 PM
csaverline
12-08-2002 07:18 PM
Quick Reply: not much smoke?!
