No Waste gate boost
No Waste gate boost
No Boost; when idleing(about100rpm too low) can hear a distinct irregular ticking sound; coming maybe from injector pump. Brought it to DODGE. Thy're trying to figure it out. (RIGHT !) . They told me if a new diaphram was needed for the waste gate actuator, DODGE only sells the COMPLETE waste gate/Turbo assembly. They said I could probably get just the actuator aftermarket.
lost boost before, but repairing air press line from manifold to divider "TEE" fixed it. This time it's not the problem. Any suggestions ; ie actuation pressure, etc, will be appreciated. DODGE charging me $100 per hour to ponder over what the problem is.
Really helps to know what year truck you're concerned with - could be a VP44 problem - but clamp off the line at the wastegate, take it fer a spin - be prepared to hold onto yer suspenders, cause it won't back out till you do - shouldn't hurt unless you tow, then would be best to have a Boost gage and EGT guage
Kaysee
10-31-2011 08:24 AM
nasty01cummims
04-23-2009 07:36 PM
whiteknight
17
01-08-2003 10:38 PM
