No Speedometer
Old 07-19-2008 | 09:31 PM
Ra'am's Avatar
No Speedometer
Truck is a 97,2500,4x4,auto. Belongs to a buddy. Speedometer would work fine sometimes and then starts jumping around. I replaced the two sensors, the one on the tailshaft housing and the one on the lower left side of the tranny case. Now speedometer wont work at all. Any ideas?
Old 07-20-2008 | 11:06 AM
Ronco95's Avatar
The ABS sensor in the rear diff actually drives the speedo. Sounds funny I know. Pull the harness off the ABS sensor and go for a ride and see if anything different happens. My friend with a "99 had a problem with his trans not shifting. Ended up being the trans sensor. You would think that was for the speedometer, but its not.
Keep asking around and you will probably get the same replies.
Ronnie
hvanflee
07-12-2005 08:14 AM
ridofpwrstroke
03-08-2003 12:18 AM
ridofpwrstroke
03-07-2003 07:08 PM
awmasparky
02-09-2003 01:04 PM
Dodgezilla
12-03-2002 12:16 PM
Quick Reply: No Speedometer
