No overdrive or cruise all at same time?
Old 06-05-2010, 10:21 PM
thegoat86's Avatar
I did. Most are clock spring for lost cruise. Speed sensor, engine speed sensor, fuses, grounds, little box behind glove box for OD. Thats all been checked. I send a ground to the PCM through a toggle and get normal operation. I dont mind that. I would like to have cruise though. It gets boring and my lazy foot gets tired holding the pedal. wahh...
Old 06-07-2010, 10:34 AM
96cumin's Avatar
my crusie started working but i can only go 70 now wen using the crusie but when not in crusie still doesnt like going over 60 and rpms ping out. is my tans bad? im confused i really dont have much experience with diesel engines just gasers..i need help!!! could it be vacume?
Old 06-07-2010, 10:46 AM
Lil Dog's Avatar
96cumin
There is a vacuum line that can go bad feeding the cruise control. That may be an issue.
thegoat86
There may be a fault with a transmission temp sensor.. I wonder if that is sending the tranny into its non-lock warmup mode. But for the cruise, I would check the vacuum to it as well as the wires. The controller is in a bad spot under the battery and can get corroded wires or the vacuum line gets some holes in it.
Old 06-07-2010, 12:14 PM
96cumin's Avatar
well im sure the curise isnt working right becasue of the tranny not shifting into od.. so it doesnt sound like a bad torqe converter or tranny. wat would you recomending me doing first to try finding the problem?
Old 06-07-2010, 12:48 PM
Lil Dog's Avatar
You could try to jumper the trans temp sensor out with a 1Kohm resistor and see if it fixes the problem.
Old 06-07-2010, 01:38 PM
Lil Dog's Avatar
Another thought was the TPS and the TV cable adjustment. If these are out of adjustment, that could provide the same symptoms.
I have to find the link for setting the TPS voltage and testing.
Old 06-08-2010, 11:01 AM
96cumin's Avatar
how do you jump the tranny temp sensor
Old 06-08-2010, 12:40 PM
Lil Dog's Avatar
I'm trying to find a good link to that. In 95, the tranny temp sensor is in the cooling lines, on 96 and up, I am not sure exactly where its located. You would basically unplug the sensor and put the resistor across the terminals of the plug.
Here is the TPS adjustment link.. dodgeram.org-TPS_adjust.htm
Old 06-09-2010, 05:05 PM
thegoat86's Avatar
I dont have lockup on the 46rh lil dog. I will replace the sensor on the trans cooling line. But why would this affect my cruise? Plus if I had a vacuum leak I would assume my brakes would be affected. I will check the controller and /or replace it. Too bad they dont make a majic answer for this issue. Seems like alot of us guys lose this in our trucks. If someone was able to fix this problem successfully, they should post it in the fixin forum.
Old 06-10-2010, 02:36 PM
thegoat86's Avatar
Magic-sorry
Old 06-10-2010, 02:41 PM
Lil Dog's Avatar
Well the cruise is a long troubleshooting string to do.. Start with the basics such as power and vacuum and then move on to troubleshoot the rest like power to the module, cable condition etc and eventually it could be a ruptured diaphram in the controller itself for cruise.
The lock up is a separate issue IMHO.
nintythree2wd
05-21-2010 07:52 PM
J Lent
60
11-03-2009 09:14 PM
shaunbolton
08-05-2009 05:10 PM
jmccart
01-18-2007 03:26 PM
samahi72
09-12-2006 07:47 PM
Quick Reply: No overdrive or cruise all at same time?
