NO black smoke once it gets turbo boost- 215 pump
#31
Originally Posted by halerazor
mine didn't smoke with just a plate, just a little with 370's and the dv's really brought it on. i still think you have a boost leak somewhere. i finally realized what these guys meant that smoke don't equal power. yeah smoke is cool , but any more fueling mods before getting a bigger turbo is a waste of money. i easily have enough fuel to get over 500hp, but i dynoed this summer at 296hp using a stock turbo
#32
How much boost were you making at 2000rpm when you had the single turbo on? If I floor it I make only 18psi which climbs gradually to 3000rpm when I start getting near 30psi and smoke comes on if I go much higher which must be due to the limitations of the stock turbo. I rarely use that many rpm so I'm fine with that.....
Interesting that the fuel shut solenoid(?) was at the root of your problem and what about the rubber line from the manifold to the afc housing? I want to make 30psi at 2000rpm with good clean power(no smoke thanks). Is that too much to ask with a 4k gsk?????
gfmccutc77
12-20-2013 08:59 AM
gopokes
06-28-2007 12:51 PM
12valve
11-29-2005 09:48 AM
bensdad_canada
05-09-2005 10:56 PM
