no 4WD light?
I think the switch is when the slider , slides in the front axle. When mine didnt light, (even with the transfer case in) it still wasnt in 4wd. Mine was a damaged vacuum line. If you had the trans out, you probably didnt plug something back in that goes to the front axle (pass side). I think the vacumm signal comes from a actuator at the transfer case, cause I remeber the line running across the crossmember I think.
Also look on the ride side of the frame up were the surp belt is. I had a belt come to pieces and the 4wd light wires on the side of the frame were cut by that belt. This was on my very first CTD, 97'.
p0wd3rp1l0t
06-27-2012 10:29 PM
wrangler04
07-17-2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
12-29-2006 07:17 PM
95black2615
12-20-2006 06:37 PM
1320
05-06-2003 06:30 PM
