Newb NV4500 swap issues
Got my trans in, and after allot of snooping finally found a shifter for it. Now that I have the shifter in the thing only feels like it has 4 gears, does the inside of that thing look right to you guys??
I also have no idea on which 2 wired are the ones for the reverse light, I have the adapter but don't know which wires to splice in.
Any help for a retard is apreciated
Shifter top looks fine from memory, try manually moving the forks with a screwdriver/bar etc. (don't force it too hard in case something is jammed up) but remember that far right is 1-2 (rear, forwards), middle is 3-4, and the left set is 5-R. Try rocking the output shaft back and forth with the clutch in if they won't go into gear easy. Is the trans used from a donor truck?
For the reverse lights, there should be 2 old connectors from the auto. The 3 wire connector from the neutral-safety/reverse is the one you want, and the outter 2 wires on the connector should be your reverse switch. Try jumping them out with something like a paper clip and see if you have reverse light before you splice anything in because it's been a while. Good luck.
Like was said about the wiring, the two outside wires is for the reverse lights, the middle wire is the neutral safety switch. Ground that one.
Thanks for the tips guys, I'm going to see what I can do today
So I figured out the problem with the trans, the ball in the end of the shifter I got seems like it's too wide, and when it catches the middle fork it also catches the other 2. Any ideas???
That's strange. I know they changed the style of the shifter somewhere around 97-98, and the best way to match parts up is to match the year exactly. I didn't think the shifters would interchange at all, one has four mounting bolts (like my 98) and the earlier style is round and somehow snaps in. .
If that's the only problem with the shifter I wouldn't be afraid to grind it down until it clears. I remember mine was not a perfect "ball", and was flatened on the sides.
The ball should be flat sided. Grab a rule (or a caliper if you have one) and measure the width of the shift lever, and the spacing between 1/2 and 5/R rails. Has the shifter been apart at all? If the shifter isn't returning to center properly, it may be trying to push two rails at once.
02 is a 4bolt shifter top,94 t0 97 is a bottle neck top.if your shife stick has a snap ring set up ,it is for a 94-97 [bottleneck top] 98-up takes 4b0lts mount shifters.... Picture is 4bolt top [98-up] also the 4 bolt shifter has a square spacer plate that goes on between the transmission top and shifterstick mounting
