New to P-Pump
Old 02-09-2009 | 07:34 PM
DodgeMonkey's Avatar
New to P-Pump
Hey all, new to the p-pump game. I have a 92, but sadly, the Killer Dowel Pin got another one, so I have an entire 97 215 horse motor turbo and all. What are the basic things I need to do to this motor? I already have a KDP kit for this motor, and my hybrid turbo is going to be swapped over. What are the easy ways to gain some power, and what problems should I nip in the butt before I get nipped.
Old 02-10-2009 | 10:25 AM
infidel's Avatar
KDP, new style throttle cable and linkage are about the only things to watch out for.
Read this> Turning up a P7100
Old 02-10-2009 | 10:12 PM
OK, what the heck is this? What does it do? And why are the wires burned? Will this affect my swap at all?
Old 02-10-2009 | 10:16 PM
k, scratch that, I found out it's the fuel heater. Can I leave it disconnected? Or better yet, can I take it off?
Old 02-10-2009 | 10:43 PM
Tate's Avatar
There is a screen in there as well. If its not leaking, I'd leave it as is.
Old 02-11-2009 | 07:50 AM
patdaly's Avatar
Yes you can, and should unless you live in the Artic, take it off. Should be simple, the prefilter goes right where the heater was. When you get it apart, you will see the deal.
Good time to throw a new screen, 8 bucks or so at it while it is out.
Old 02-11-2009 | 08:48 AM
blackimpala's Avatar
Yes remove it and throw it as far as you can. Then just pull the adapter bolt "Allen head" and reinstall new screen and bowl. If you leave it on sooner or later it will start leaking air and you will pull your hair out trying to find the leak.
Floyd
camerd18
08-21-2008 07:20 PM
vgwood
03-31-2007 08:57 AM
jbevly
09-05-2006 03:59 PM
blh1960
02-28-2005 03:40 PM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: New to P-Pump
