New IP, no OD
Old 09-09-2009 | 05:37 PM
94DK107's Avatar
New IP, no OD
Like the title says, put a new IP in and the truck runs better than ever. Was going to take it on a road trip to test everything out, and no OD.. Short trip. I replaced the TPS last year when the tranny started going in and out of OD, that fixed that problem. Now it's not even trying to engage, no matter how much you baby or hammer on the throttle.. It goes through the rest of the gears just fine. Before I changed the IP, it shifted great. Any idea where to start?
Old 09-09-2009 | 07:05 PM
infidel's Avatar
First make sure the TPS isn't disconnected.
Then go here http://dodgeram.org/tech/transmissio...TPS_adjust.htm
You can also install a lockup switch either permanently or temp to see if the problem is electrical.
Instructions> http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old 09-09-2009 | 08:58 PM
Fueling around's Avatar
Check the throttle cable adjustment, too.
http://www.dodgeram.org/tech/transmi..._lever_adj.htm
grishfish
113
03-03-2013 10:53 PM
OOPS
08-28-2004 07:15 PM
powerwagon440
04-19-2003 07:19 AM
midwestdually
03-21-2003 09:06 AM
akchameleon
03-19-2003 12:39 AM
Quick Reply: New IP, no OD
