New injectors- stalls at idle
Old 09-22-2010 | 01:59 PM
Hodge's Avatar
I just installed new DDP injectors. The install went smooth, and the truck idles and runs out fine. But, sometimes, when it is in drive or reverse, and I let off the throttle, it dies. Not all the time, and if I feather the throttle instead of just letting my foot completely off of it, it will idle down and stay running.
It used to do this once in a blue moon, and only when it was cold (the engine). It is getting better (I have put about 100 miles on the new injectors), but it still does it. Will it work itself out, or do I need to look into something or make an adjustment?
Mark
Old 09-22-2010 | 03:13 PM
Lil Dog's Avatar
Whats the idle speed? I know mine will lope more when its cold. a little more idle speed and it goes away.
Old 09-22-2010 | 03:29 PM
Hodge's Avatar
When warmed up, it idles between 5 and 6 hundred.
Old 09-22-2010 | 03:42 PM
Lil Dog's Avatar
Is that with an external tach or with the dash? Either way thats about 200 too low. Bumping it to 800 will help..
Old 09-22-2010 | 04:08 PM
Hodge's Avatar
The dash tach. How do I bump the idle up?
Old 09-22-2010 | 04:59 PM
Lil Dog's Avatar
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
This should fix you up. I have mine a little higher near 835-850 with a phototach, but I don't have an auto so I don't have to worry about a push through when in gear.
Old 09-22-2010 | 05:47 PM
Hodge's Avatar
Thanks!
Old 09-23-2010 | 07:33 PM
Hodge's Avatar
After I got home from work today, and let things cool down, I contorted myself and adjusted the low speed idle bolt. What a difference! Not only did it cure the stalling, but now, it fires on the first hit- before, I would have to hit the starter, hit it a second time, and it would start.
Old 09-23-2010 | 10:18 PM
Lil Dog's Avatar
Glad to hear it!
Welder
01-27-2007 05:19 AM
Hounddog
02-14-2006 06:33 PM
Tiger Rag
31
12-15-2005 08:21 AM
JohnnyH
11-09-2005 01:46 PM
MIKE,J
08-29-2003 09:26 AM
Quick Reply: New injectors- stalls at idle
