new injectors and delevery valves and no top end
i just put new 370 injectors on my 94 dodge, and i put lazer cut injectors. i have a 0 plate and k&N. It feel like i have no top end now. I mean its not like its slow by any means but when i get on it it has alot of black smoke but then after i get into it a little more the smoke slows down. The power doesnt seem to be there with the petal to the floor. What could be the problem?
i put some washers in were the springs are to kick up the limiter. my brother has the same setup on a 98 12v and his doesnt have this lack of top end power.
Sounds to me like you have met the end of your turbos efficency range.Also,remember that just because you add or modify the governor springs does not mean it will make power into outer orbit past the normal efficency range.....Andy
stock timing so far need to change that. i also have the stock turbo. do i need more boost or what is the problem. I do know that i cant get any more boost out of mine nor would want to try and also know that i cant go much higher then 50 psi for my head gasket. What is the problem with my turbo if any at all? Thanks
well i changed the fuel filter and lowered the boost down to 35 psi and i got alot more power but now the egt's can hit 15k easy. So will have to keep an eye on that.
John Faughn
11-04-2008 02:17 PM
