new 12 valve, new pump, twins, 100 plate, old 180hp injectors and no power
need help making power with this ford conversion, it's a 1999 super duty with a 12v, ported head, twins hx35 and ht3b, 6.0 intercooler, 838--160hp pump, 100 plate, new lift pump, fuel pressure stays above 20-22 psi even under load, it seems to reach a full 2700 rpm, but when I road test it it has little power and will only reach 55mph top speed. I could use a few suggestions. thanks.
smokes only at first throttle tip in. yeah im sure their small im just getting it going and their what had but it doesnt make 30% the power of a stock 1st gen. Ive checked linkage travel.pulled the shut off solenoid out and im probably going to recheck my timing , it should be at 15*.
I am using a 47rh with the dodge pcm and harness. it sounds great and runs good right off idle but then runs out of fuel fast. I'll try to get some pictures later today, my wife kids and I have to work cows today. thanks for the reply.
I pulled the afc, took er' for a spin and stuck my foot to the floor and got a fair amount of smoke and some power. I dont have my boost and pyro in yet so i dont have boost numbers and idont have the right harmonic balancer for the tach signal so no overdrive and tc which with 4.10 gear tops at 60 mph but, its getting narrowed down pictures are coming.
city slicker
05-21-2012 10:13 PM
