Need your guys input!
Old 04-12-2009 | 01:03 AM
Buzz'nhalfdozen's Avatar
Need your guys input for turbo upgrade
I'm in the market for a new turbo. i'm not looking to make huge power i've got the truck where i want it power wise. i'm just looking for something thats a step up from the stock. i want some thing thats gonna be reliable and in the $1500 to $1800 range. O i also plan on putting a pacbrake PRXB and an intercooler upgrade (not sure on this one either) so i want them to all work together as well. i know thats alot but thats why i'm asking the best.
Thanks guys
Old 04-14-2009 | 10:52 PM
RCW's Avatar
RCW
I would not change the turbo, but would install the 4" turbo outlet kit and the four inch downpipe, and it is like installing a much larger turbo, but for a lot less money.
Then find a motorhome or bus manifold inlet horn and replace the Dodge unit with the much larger motorhome inlet and larger hose from the intercooler to the horn. You just eliminated a huge power waster in the OEM restricted air inlet.
When you are done it will feel like it has a well tuned HX40, but the cost will be a few hundred and your EGT's will drop significantly.
Old 04-14-2009 | 11:19 PM
thanks ill look in to that
Old 04-14-2009 | 11:27 PM
Lil Dog's Avatar
If it were me, I would look into either an upgraded HX35 from PDR or get into the S-300 variants by HTT or II. I have a smaller S300G and its a little tight for what I would like. Stepping up to a 64-14-71 is what I have been contemplating. I think this S300G is a 62-12-65(?) not sure, but the exhaust side is too small. HOT!
Old 04-14-2009 | 11:32 PM
J.Suplanski's Avatar
Turbo's
I went with HX 40/16 with 370's injectors and just lovingit! ATS manifold also!
Old 04-15-2009 | 11:38 AM
infidel's Avatar
Make sure you get an inline exhaust brake rather than one that replaces the turbo elbow.
With the elbow type you are severely limited if you ever want to switch turbos.
Most e-brake manufacturers offer an inline for about the same price.
Old 04-15-2009 | 05:19 PM
Tate's Avatar
The S300G is a 57mm compressor wheel.
Old 04-15-2009 | 10:54 PM
Lil Dog's Avatar
I guess its not the G then. It is a 62, just weenie on the exhaust side..
danny1944
Introductions / New People
11-02-2010 10:00 PM
patdaly
10-04-2010 12:40 PM
Charlie C
07-29-2010 08:45 PM
Patriot2500
29
06-13-2008 10:55 AM
Joe Diesel
11-12-2007 09:59 AM
