Need to know what I have.......
Old 02-10-2007 | 08:04 PM
displacedtexan's Avatar
Killer dowel pin, it's a pin in the timing case, used for alignment that can back out and fall into the timing gears, causing major damage.
http://www.tstproducts.com/index.asp...PROD&ProdID=64
Old 02-10-2007 | 09:12 PM
JKM's Avatar
JKM
Originally Posted by smokeum99ta
Thanks . So I can just take off the plate and grind away to match something similar to what you have drawed up and that will give me more power. Also where is this plate at. Can I see it just buy standing in front of the truck? Also where can I purchase a spring kit at?
You can't see the fuel plate itself from outside the truck , you need to remove the AFC housing, it is not hard to do at all , there is one "break off" screw , that can be a pain to remove sometimes , but not always , other than that , 4 bolts and it pretty much comes off (some people remove the intake horn) , unbolt the plate , bolt the new one in , adjust the goveroner lever , and put it all back together.
You can purchase a GSK from lots and lots of vendors, I got mine from Piers Diesel Research www.piersdiesel.com
Old 02-10-2007 | 09:41 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
What is the "KDP"
All these abbreviations are killing me....
A quick visit to the Tech Facts section can alleviate much of your anxiety
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old 02-10-2007 | 09:56 PM
Geico266's Avatar
A quick visit to the Tech Facts section can alleviate much of your anxiety [/URL]
Or increase it by 100 times.
Congrats on your find! Many guys are dying to find a 97-98 12v. You hit the jack pot!
Old 02-10-2007 | 11:01 PM
smokeum99ta's Avatar
Man does that help out. I guess i'll have to put that one in my favorites for a quick referance
TayTay
69
05-13-2015 03:42 PM
Firstgenfanatic
02-18-2009 09:54 PM
bigragu
01-25-2008 12:37 AM
PurNLoud
09-08-2006 11:40 PM
JKM
07-03-2005 04:59 PM
Quick Reply: Need to know what I have.......
