Need help trouble shootin my tranny
Old 10-21-2006 | 05:19 PM
~Angry Tractor~'s Avatar
I have a 96 4x4 ctd auto. I looked under the hood and it doesnt say if its a 46re or a 47re all it says is "STD 4sp auto - CHR". What its doin is slippin. Its been sittin for a while and I started it up this morning, warmed it up in neutral, made errands and noticed it was whinning a little. I stopped for about 10 minutes at a sale and when I took off I mashed the pedal a bit to get on the highway and the engine revved pretty good but the truck didnt move all that much. I backed out of it and the tranny caught up to the engine so I babied it home. It will shift if you ease into it but if you give it too much it slips. So after all this rambling I guess my question is: Is it the bands slipping or is it the transducer and I think theres a selonoid too? I'm not too knowledgeable about trannys, but I won't hesitate to tear into it if Im pointed in the right direction. Thanks for any help you can offer.
Old 10-21-2006 | 05:23 PM
wv smoker's Avatar
Hopefully it is just low on fluid or the filter is clogged up??
Old 10-21-2006 | 05:28 PM
Nope fluid was good I checked it in neutral. I dunno about the filter. I can't get to town right now to get one. I got a feelin it's a bit more then that. I'm hoping a band adjustment will do it, but I dont wanna adjust them if I don't need to. I was hoping someone might recognize if those symptoms pertain to bands or transducer/seloniod?
Old 10-21-2006 | 06:35 PM
CarcajouCummins's Avatar
The front band is second gear, and the rear band is reverse (and manual low). A band adjustment will only help if second is the only one giving problems. Put pressure gauges on it and see what it is running at.
Old 10-21-2006 | 09:01 PM
OK Ill get some gauges. I guess NAPA carries them? They'll be closed on Sunday. Would O'riellys have them? Any reference on setting them up? I did a search and didn't come up with anything.
Old 10-21-2006 | 11:15 PM
If you have a grainger nearby, you can get liquid filled for $8 or so. You will need 200 for checking the accumulator port, and 300 if you plan to check reverse pressure. The trans takes a 1/8th pipe thread on the test ports. I use push lock fittings and about 5 foor of push lock hose to plumb it up to where I can read it while on a road test. Push lock fittings and hose is available at any hydraulic shop.
Old 10-22-2006 | 08:08 PM
Well I went out this morning and took off in the truck and it hasnt slipped yet. It is still whining pretty bad. The fluid looks good and doesnt smell. I will be flushing and putting a new filter in tomorrow. I'm not sure if I will adjust the bands. I hear it's not good to do that unless you are sure that is the cause of the slippage and I'm not sure. Is there any measurement I can take to see if the bands are where they need to be feeler gauge or something? Thanks
Old 10-22-2006 | 11:16 PM
The lever for the front band will have roughly 5/16 inch between the anchor and the servo.
Old 10-23-2006 | 02:37 PM
I never thought changing a tranny filter could get so complicated. The filter Advance Auto gave me doesn't look anything like the one I just puled off the tranny. Now I have to put the old one back in top off the fluids and go back to town to look for the right one. Anyone have a good Napa part # for the 47RE filter? I aint goin back to Advance.
Old 10-23-2006 | 04:06 PM
inarush76's Avatar
The 96 filter should be a flat all fiber filter, while the 98 up filter is metal/plastic. If you have trouble getting the right one, use an application for anything from 62-up Chrylser/Dodge 727,518, 47rh, 47re. All the early 727's in big block and some small block trucks and vans used the same filter and gasket you need for the 96 model. Hope this helps.
James,trans builder
Old 10-23-2006 | 08:45 PM
You can use either filter. The black one is held on by two screws instead of three. Put the third in its hole and tighten it up.
Old 10-24-2006 | 01:11 AM
I went ahead and ordered a high dollar one from Napa. Should be in tomorrow. I didn't like the way the one from Advance fit up. It didnt seem to have the clearance that the other one does. Thanks.
Old 10-24-2006 | 10:30 AM
Diesel nut's Avatar
Ad removed site violation
Old 10-25-2006 | 11:02 AM
Well I still have some whining in the tranny after filter and fluid replacement, but no slippage as of yet. When I get the gauges on what kind of pressures should I see and does that diagnose a particular failure in the transmission?
ridlangus123
12-30-2013 09:36 PM
phantom 309
10-09-2008 08:50 PM
Teddy Bear
19
03-19-2007 06:31 AM
scottsjeeprolet
10-18-2006 07:29 AM
Mark Thomas
09-18-2004 12:45 AM
