Need help with bolt torque! Pressure plate, and flywheel!
Hey guys,
Does anyone have the pressure plate bolt torque spec and the flywheel to crank bolt torque spec???
Thanks!!!
Thanks!!!
25 ft lbs for the pressure plate bolts
101 ft lbs for the flywheel bolts
If your clutch didn't come with new pressure plate bolts, then go get some new grade 8 bolts. The original flywheel bolts are fine.
Derek Timm
03-14-2008 12:28 AM
