Need help
Old 02-13-2009 | 03:55 PM
bgjj's Avatar
Need help
Have 1998 2500 12 valve
tranny is in limp mode
error codes
P0753 Shift Solenoid A Electrical
P1765 Transmission 12 volt supply relay control circuit
Transmission relay is good, changed out the speed sensor on tranny,I believe Solenoids in tranny are good because if I put a jump wire where the trans relay is from its power #30 to where it is surpose to close # 87 the tranny shifts fine, so what ever makes the relay close must be my prob I think, anyone know a procedure what, where, to test to track down my prob.
Old 02-14-2009 | 08:08 PM
bgjj's Avatar
No electrical guru's here??
Old 02-14-2009 | 11:04 PM
oldblues's Avatar
hi
i have had that code and by simply erasing the code it corrected the problem .
erase it and test drive it and see if the code returns .
Old 02-15-2009 | 06:26 AM
bgjj's Avatar
done that, just comes back
smokin24v
03-18-2008 01:21 AM
pwrtripls1
02-08-2008 07:25 PM
spooling
09-13-2007 10:05 PM
coupdetat
01-17-2007 09:23 AM
Quick Reply: Need help
