Need Assembly help ASAP Please
Do you guys use and sealant on any gaskets? I know gaskets are gaskets but I do NOT want any leaks so should I use some "The right Stuff" or not????
I used some sealant on the oil pan gasket but probably not needed. Just a habit when I put engines together. Also I have used some rtv on my intake manifold gasket because I blew my stocker out.
1 Post
well, i'm personally not a big fan of gasket maker. If your surfaces are clean and free of oil, you should be safe to use good quality gaskets.
make sure you follow a torque sequence.
BlueDodgeRam
11-07-2010 07:23 PM
pwrtripls1
01-15-2009 10:35 PM
tony597fitter
03-10-2007 04:14 PM
