My Mechanic??? Fuel Filter not screwed on
Old 06-18-2008 | 12:05 PM
barngal6's Avatar
Fuel Filter cannister just fell off after I removed the top bolt!
Fixing a hose leak by preheater
Went to remove fuel filter, unscrewed the top bolt and boom, the whole
filter/cannister just fell down!
Was just replaced by my mechanic.
And the fuel I drained is completely red--he told me ATF makes diesel
engines very happy, and I can understand that it was probably more
readily available than diesel fuel to fill the filter cannister.
I only drove about 3 miles since the filter change, but shouldn't the
ATF have mixed with the diesel fuel?
Old 06-19-2008 | 08:11 AM
patdaly's Avatar
On 97-99 thats the way they work, the center nut is all that retains the cannister.
When you put it back, make sure you "clock" the cannister correctly, there is a tab towards the front that fits in a slot on the base.
3 miles isn't enough to remove all traces of red, you probably had a mix still in there.
BTW, ATF is a no-no in mine, but to each his own.
Old 06-19-2008 | 07:50 PM
MikeR's Avatar
Right ATF is bad ju-ju. It has friction modifiers to help surfaces to grip.
That's not something you want in a fuel system.
Old 06-20-2008 | 01:10 AM
barngal6's Avatar
Thanks,
I'll get rid of the ATF and fill with diesel...
and thanks for the tip about how to line up the filter cannister,
saved me another post
Hunky Dory
05-13-2013 08:09 PM
frank67
06-30-2011 06:27 PM
bcgirl
30
08-12-2008 04:46 PM
Common
20
08-08-2006 07:56 PM
FastSS
14
11-15-2002 07:51 AM
Quick Reply: My Mechanic??? Fuel Filter not screwed on
