Is my KDP in the oil pan?
I've been thinking about tabbing the KDP when the weather gets warmer (I don't drive this truck in the winter so I've got plenty of time) & I happened to remember some years ago (truck had maybe 80K at the time, now 273K) when I was changing the oil I stuck my finger up through the drain in the pan & felt some kind of small object with the tip of my finger, but it rolled/moved to the front of the pan out of reach, so I never found out what the heck it was. Never thought any more about it until I heard about this KDP problem - is there anything within reach of one's finger such as a sump/pickup or anything in that area? Is there anything else beside the dowel pin that could come loose & fall down there? I guess when the weather's warmer I'll just pull the pan off and look, but for now just curious.
Steve
Steve
I need to replace the radiator because of a small crack in the plastic tank on one side so that might be a good time to pull the gear cover & take a peek. Just curious though as to what it might be - this engine seems very well built & you wouldn't think parts (besides the KDP) would just somehow fall off from up in the crankcase.
Steve
No oil leaks - it uses/loses maybe half a quart over 6K miles between oil changes. If by chance the pin has fallen down into the pan, is there any reason to put it back?
I feel that there is, it helps hold the weight of the gear housing. If the bolts get loose, and they do, it will hold the housing in the proper position.
Floyd
Floyd
EverydayDiesel
11-11-2007 09:33 AM
MrKen
11-23-2006 03:19 PM
bostongsx
09-25-2006 11:25 PM
