My 96 has no fuel primer button. Help!
Old 04-16-2013 | 06:27 AM
mtdoragary's Avatar
I've replaced the fuel filter and need to bleed the filter. My lift pump has no primer button. It looks like a new replacement pump. How do I bleed the filter?
Old 04-16-2013 | 06:57 AM
Hodge's Avatar
Can you post a photo of the lift pump? I haven't seen a lift pump for a 6BT that didn't have a primer on it.
You can also open the bleeder on the filter housing, and pressurize the fuel tank with an air hose. That will push the fuel through to the filter, fill it up, and come out the bleeder.
Old 04-16-2013 | 07:50 AM
mtdoragary's Avatar
My mistake! I was looking for the primer button to be on the pump, not next to it! After a third gen and another 1st gen, coming back to a 2nd gen is somewhat of a learning curve.
Old 04-16-2013 | 10:14 AM
joem's Avatar
iv replaced my filter several times and never used the primer- I just fill the filter with fuel or diesel purge and screw it on fires up every time with very little stumble.
RoadDiesel
12-29-2014 09:11 AM
Tedonlin150
02-04-2010 11:37 AM
can17
11-10-2008 02:53 PM
GuitarGerber
02-25-2008 10:21 AM
Katmandu
08-18-2006 06:11 PM
Quick Reply: My 96 has no fuel primer button. Help!
