To much fuel on #2 cylinder?
Old 04-30-2008 | 05:13 PM
12ValverDave's Avatar
I just got back from a 600 mile trip, when I got stuck in traffic my truck would puff white smoke on take off, and has a miss when idling, I cracked the injector lines and #2 is bubbling a heck of a lot more fuel then the others. What would cause this? Stuck DV or Plunger?
Dave
Old 04-30-2008 | 09:07 PM
Fueling around's Avatar
Bad injector
Old 04-30-2008 | 09:12 PM
daking's Avatar
unless theres an injecotor in the pump he said it was to much coming out of the injection line not the injecoter witch is after the line, but heck what do i know
Old 04-30-2008 | 09:21 PM
Yeah whats causing my pump to pump to much fuel to cylinder #2? Its not the injectors they are new
Old 04-30-2008 | 09:33 PM
A stuck plunger doesn't pump fuel. At idle, the engines runs really rough. You often hear a very loud clicking.
A stuck delivery valve will let fuel out of the line back into the plunger.
New injectors? Either you have a bad tip or a sticking pin. This allows cylinder pressure to push the fuel out of the injector.
Old 04-30-2008 | 09:38 PM
Im 99% sure its not injector related, so to much fuel to a certain cylinder wouldnt be a stuck plunger but instead a?
Old 04-30-2008 | 10:17 PM
Originally Posted by 12ValverDave
I cracked the injector lines and #2 is bubbling a heck of a lot more fuel then the others. What would cause this? ...
Bubbling fuel is a sign of air as well as the white smoke. Being you isolated to #2 cylinder, I suspect the injector
Old 05-01-2008 | 09:43 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Dave......Send Tate a PM....he maybe able to help you.If you have time remove the #2 DV and check if something got lodged in there...
Old 05-01-2008 | 01:51 PM
aksparkey01's Avatar
yea i was thinking a bad sping in the dv holder. of if they have been out before someone might have lost a shim.
Old 05-01-2008 | 03:52 PM
Tate's Avatar
Don't go dragging me into this . . .
If there is bubbles, that means there is gasses (air) in it. If you have a stuck plunger, like was said, you're not gonna be pushing any fuel. I'd imagine the rack would be pretty sticky too if the plunger is stuck. I'd go with Fuelling Around's suggestion and look at the injector. Swap the number 2 with another another cylinder see if the symptom moves. If it does, then its the injector. If it stays on the #2, then you either have a pump issue or an engine issue.
Gen414
05-07-2009 11:08 AM
cgmorgan06
11-15-2007 04:02 PM
Camarogenius
19
03-29-2007 10:44 AM
moparguy
04-01-2006 10:32 AM
Journier
11-22-2004 02:56 PM
Quick Reply: To much fuel on #2 cylinder?
