MOOG or NAPA ?
MOOG or NAPA ?
I've been researching these front end parts and a curious to see if anyone here as any experience with NAPA steering parts? It seems they have a cheap line and an expensive line. They got one track bar for 140.00 and another for 230.00? I was reading on another forum that the NAPA parts are much beefier than MOOG. This is starting to drive me crazy and I need to pull the trigger on something like yesterday. My local guy is getting me the MOOG parts but I can have him send them back if the NAPA's are better.
Don't know if it's still the case but when I bought my Napa bar many years ago it came with a lifetime warranty.
Hard to beat that.
I've replaced mine three times as recent as last summer, no questions asked.
Hard to beat that.
i use to do automotive suspension work daily. my best expierences were with moog parts. didnt care much for the cheaper line that napa sells. if you compare the tie rod ends for a dodge truck napa against moog you would definetly go with the moog.
I paid about $300 for my DThuren track bar. I don't see either of those replacement track bars worth the money, in comparison.
The Napa part has a lifetime warranty, but you have also changed it three times, which is a lot of labor. The DT unit went in three years ago for me, and won't have to be replaced for a long time.
I just don't see the reason to go cheap on this one.
As far as the rod ends, I went with Moog on all of mine.
I've averaged between 40-75k per bar which includes quite a bit of potholed Forest Service roads.
Cost and hassle wise I've been happy with the Napa bar.
I went with the NAPA track bar. It does have a lifetime warranty for as long as I own the truck which will be a long time...lol Then I went with the MOOG for the steering linkages. I got the 99' HD stuff to convert my 95. The 99' stuff is major beef and almost twice as thick as the 95' stuff. Also a much better design. I'm happy !!
you will love the 99 hd steering. definetly worth it. i did it to my 97. it was great! i didnt have time to intall a steering dampener on it befor it got stolin but i never needed it either. if you are going to put one on. my 98 with the same steering setup had the fox one from kore and it is great!
As far as 40-75K, my track bar was replaced at 170K with the Napa unit, and by 200K it was toast. It was almost all onroad driving. The DThuren bar has about 25K on it.
Have you considered (since you are researching this) to upgrade to 1998/1999 parts where they changed from a inverted "Y" style to the heavy duty crossover style. The problem with the "Inverted Y" style is when your ride height changes so does the Toe. With the crossover Style you go from the pitmam arm to the right side and you have a solid bar going from the right to the left.
Moog part numbers
Long tie rod: DS1456
Drag link: DS1459
Left tie rod end: ES3496
Drag link tie rod end: ES3497
Small adjusting sleeve: ES2012S
Large adjusting sleeve: ES3498S
This is something I am considering for myself, but have not done it yet. The only problem is how to mount the steering damper.
Moog part numbers
Drag link: DS1459
Moog part numbers
Drag link: DS1459
Moog part numbers
Drag link: DS1459
I work at NAPA on Saturdays (Mainly for the discount) and we will not sell the cheaper line for trucks. For most cars it works just fine but I definitely recommend the better line for our trucks. I put a set of ball joints (the cheap line) in my last 97 and they were out by 10K.
